We are using 89C51RD2 with standard 12 clock stand mode, in this Timer 0 we are initializing with following snapshot code and expected to fire interrupt for every 10mSeconds approx.:
INI_TIMER0() { TMOD &= 0xF0; TMOD |= 1; TL0 = 0xE5; TH0 = 0xBE; ET0 = 1; TR0 = 1; }
But when I check firing intervel in one of the port line by using CRO I am getting 40 mSeconds. to check I used following code:
void Timer0Handler(void) interrupt 1 using 3 { static unsigned char flag = 0; EA = 0; if(flag == 0) { CEX0 = 1; flag = 1; } else { CEX0 = 0; flag = 0; } }
I changed TH0 and TL0 values several times and tested. Irrespective of my reload vales I am getting signal level change in CEX0 port line always 40mSeconds.
What's the wrong with my code? Appreciate your help.
Additional Info:
Using 20 MHz Crystal. End of void Timer0Handler(void) interrupt 1 using 3 routine reenabling all Interrupts.
