Topic: Event sequencer (for request for code for project)
Hi all you programmer people
I wnder if some kind soul can help me?
I have a project on the go which involves 10 sequencial logic level outputs with presetable times on each of the output pins
I imagine it would be very easy to do with a chip if you know how. Unfortunately I don't know even basic programming so I was hoping that someone would take up the challenge.
I don't know what the times are yet so I would need very simple instructions as to how to set and change them.
Once the correct times are set they never need changing
I have access to a programmer so have no problem with the hardware
I know programming is easy but i am very busy and don't have time. Obviously, No doubt I could learn how to do the programming, I simply don't have the time. You people know and like chalenges. here is my chalenge for you.
Thanks for any help
Mike
  • For me to use a monniker would be the same as a teetotaller taking a drink.
    If you do not believe in/like/accept/tolerate/.... something and do it yourself, you are not "practicing what you preach".
  • "Those hiding behind monninkers like sardine and bratwurst freely spill their bile and I have a real problem not responding to someone stating that e.g. my code is non-mainatinable."
    Do you remember suggesting a while ago that people like me were lazy dogs because I used the large memory model?
    http://www.keil.com/forum/docs/thread10196.asp
    I don't need to say more on this. It was already said there.
  • Do you remember suggesting a while ago that people like me were lazy dogs because I used the large memory model?
    I guess what you refer to is: I have seen "I use large so I do not have to worry about space" which I read as "I use large because I am a lazy dog"
    please note the bold portion which clearly indicates 'opinion'
    Do note the the 'lazy dog' is not the one that use 'large' but the one that use 'large' in order not to worry about space.
    If anyone has a qualified reason (not just "not to worry"), as seen by those that actually read the whole story, I do not see how it applies, unmless, of course, 'not to worry' happens to be your reason.
    Anything with a qualified reason will, of course be a qualified decision, not just "I'm too lazy".
    I could, of course, stop worrying and tell my employer that we need to use a processor that is twice as fast with twice the memory. That, however is a very unlikely event.
    Regardless, I do believe that the use of 'large' in most cases is unjustified.
  • "Do note the the 'lazy dog' is not the one that use 'large' but the one that use 'large' in order not to worry about space."
    Unfortunately, that was not the way the posts in the original thread actually read.
    I will just remind you: What I saw as the problem was someone posting opinions in a manner that appeared to be authoritative. An action that would probably lead to less experienced people thinking that these opinions are desirable targets; thus limiting their armoury of methods open to them when developing code.
    And taking Jonny Windapeg advice, I will now say this:
    <NotWrappedInPinkCotton>
    It is my opinion that the poster whose posts need curtailing most is the ardent moniker hater himself (aka Mr Ego).
    </NotWrappedInPinkCotton>
  • Those hiding behind monninkers like sardine and bratwurst freely spill their bile
    How would you then qualify many of your own posts that are spread throughout this forum? You have been very proficient in spewing your own bile, sir. In this case, you certainly practice what you preach!
  • How would you then qualify many of your own posts that are spread throughout this forum? You have been very proficient in spewing your own bile, sir. In this case, you certainly practice what you preach!
    there is a difference between starting the crap and "responding in kind"
  • "there is a difference between starting the crap and 'responding in kind'"
    That would be a very, very tiny difference then.
    It is way better to not respond at all, if you know that you can't control your temper, or your tongue.
    Most companies would throw out people who can't control their outburst, even if it only happens after provocation.
    You can never win - or even get close to winning - a debate as long as you can't control your temper. The opposing side will always get the upper hand since they know that you will _always_ loose control.
    When in need, leave the keyboard and take a 5min stroll. When you get back and are about to send a response, ask your self this question: Would it be safe to say this to a very big and very mean looking and slightly intoxicated guy you meet in the shadier part of town? If in doubt, try to rephrase before posting.
  • Per,
    You are an all-in-one package: technical guidance, safety guidance, spiritual guidance ! Cheers!
  • pls send me a ping so I can e-mail you.
    I realize that my response to your post would trigger a flood of posts, and if this dog is sleeping, let us let it lie.
