Hi all,
I'm brand new at this. I'm in microVision coding for an ADuC7026 eval board from Analog. I have some preexisting code that works fine. However, I need to add a UART interface to this. Pulling the block of lines right out of a working (and tested) example from the manufacturer, I place it into my code (at the beginning of my main function, as it is in the example). I copy the entire routine for Setting up the correct tx/rx pins and just initializing the UART connection. Taking a UART example that includes a printf hello world function, the code does not compile. I end up with syntax errors marked starting at the preexisting code (what comes right after what I've inserted). I end up with the following errors all over the place:
CAVITY.C(47): error C25: syntax error near 'unsigned' CAVITY.C(54): error C25: syntax error near 'volatile' CAVITY.C(54): error C25: syntax error near ')'
And so on. I have no idea what this is trying to tell me. The string 'volatile' isn't even in my code. This just won't work. This is the code I've inserted:
// Setup tx & rx pins on P1.0 and P1.1 GP1CON = 0x011; // Start setting up UART at 9600bps COMCON0 = 0x080;// Setting DLAB COMDIV0 = 0x088;// Setting DIV0 and DIV1 COMDIV1 = 0x000; COMCON0 = 0x007;// Clearing DLAB GP4DAT = 0x04000000; printf ("Hello World\n");
Again, this is taken straight from a working example. Any insight would be GREATLY appreciated. Thanks.
Can you show the source code lines around the error message, and point out line 47 or 54.
Do you have any conditional compilations?
Might you have a text sting that is missing the termination quotation?
Might there be an expression with a missing parenthesis?
Or a statement block with nesting errors of braces?
One thing you can do is request that the compiler generates an output file after running the preprocessor. In case a define results in stupid code replacement, the preprocessed source - when compiled - will clearly show exactly what the compiler saw.
Thanks for all your help, by the way. I had to wait until today to get into the lab to get the code. Here's my code with comments where those errors (which are a very small sampling of the errors) occurred:
int main (void) { ///TESTING UART CONNECTION/// // Setup tx & rx pins on P1.0 and P1.1 GP1CON = 0x011; // Start setting up UART at 9600bps COMCON0 = 0x080;// Setting DLAB COMDIV0 = 0x088;// Setting DIV0 and DIV1 COMDIV1 = 0x000; COMCON0 = 0x007;// Clearing DLAB GP4DAT = 0x04000000;// P4.2 configured as an output. printf ("Hello World\n");// printf function call //END UART TESTING// // Table is placed in Flash/EE; unsigned short TableS1[N]; //This is "line 47" unsigned short TableS2[N]; float i = 0; int j = 0, k = 0, l=0; int n1=R1/R2, r1delay=0; GP2DAT= Pn2Off;//Error signal//This is "line 54" GP1DAT= Pn2On;//Modulation
I reach syntax errors "near" both of these lines and continuing down the rest of my code. These errors don't exist when I try to compile without the UART configuration block of code. If I try to just comment out line 47, I end up with the same error at line 48.
I've played with my code a lot to try to find an actual syntax error, but I can't find a thing. It just doesn't make sense to me that it would compile without the inserted code, but hates me when I do add it. I'm not that experienced with C, so maybe I'm making a silly mistake?
I couldn't find a way to make uVision produce a preprocessed output. Any hints?
Thanks. -Larry
You didn't show the definition of N. Is it a preprocessor define? Might you have a comma or other extra character around the defined value?
N is defined in a header. But if there were a problem in the header file, wouldn't that cause it to not compile even if I didn't insert that block of code?
I got the code to compile by moving the code block slightly down. Somehow, this allowed it to compile. Thanks for all your help!
It was to obvious to be visible :)
When compiling C programs, you have to have all variable declarations before the code statements.
Ah okay. I didn't know they all had to be declared first. Thanks!
