hi
Im new user of cortex M3 with STM3210E-EVAL board and i use ulink 2 to debug but i have this message whene i try to debug "could not stop cortex M device please check the JTAG cable", if anyone have a solution for this problem, thanks in advance.
that is because your cortex can't be reset,maybe you reset pin connect to GND all the times,so no reset signal to stop the MCU.
I don't think this is the reason. the JTAG clock is probably not configured correctly. set it to RTCK.
