Evaluation tools, board and programmer for 8051 novice
In order to begin to learn 8051 development I am considering using AT89C4051, Keil Evaluation software in conjunction with Allen Systems Micro Byte-51 board and <some programmer >
Would someone be kind enough to recommend a Programmer ( off-the-shelf ) that is compatible ?
The AT89C4051 has 4Kbyte program memory so will be OK with startup code and starting address for program I believe. I am aware if the 2Kbyte code limit for executable.
Thanks, Sean
