PDATA linking
I am trying to get the pdata access to work but keep running into this
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: PDATA SEGMENT: ?PD?RAE LENGTH: 000026H
I am using the actel core8051 module.
The STARTUP.A51 pdata is set as follows:
PPAGEENABLE EQU 1
PPAGE EQU 0xBF
PPAGE_SFR DATA 0A0H
The only thing in the program I have declared in pdata is a 26 byte structure.
I set PDATA(x:0xBF00-x:0xBFFFF) in the userclass for the LX51 linker.
I indeed see this PDATA space allocated (or maybe recognized is a better word) in the *.MAP file, but of course the image isn't created because of the error.
When I do this I always get the error listed above. However, if I do not include the PDATA info to the linker, the program compiles without error (but I assume the pdata would point to 0x0000 if the linker doesn't know better).
What am I missing here? I was trying to set this up to map to xdata space 0xBF00-0xBFFF.
Eddie
0
