I am using rtx kernel and mdk 3.40 with LPC2468, the functions fopen,ffind,fclose works very well, I can create files, read and write those very good. When I call fformat("f:"), the lpc2468 reset and starts again but the flash was formated ok, Someone knows why this happens. If I run the em flash example for mcb2400 without rtx kernel this work fine. thanks
watchdog reset? maybe this link can help: http://www.keil.com/support/docs/3377.htm
I do not use any of this functions: STR91x: 'spi_send()' in module SPI_STR91x.c LPC214x: 'spi_send()' in module SPI_LPX214x.c LPC23xx: 'mci_command()' in module MCI_LPC23xx.c
Is this functions used for Flash Programming Functions - SST39x320x. In the FS_FLASHPRG.C I did not find any fformat or read, write sector to put watchdog refresh.
