Hi all,
In RL-ARM User guide,http://www.keil.com/support/man/docs/rlarm/rlarm_os_evt_wait_or.htm, it says that "The unit of measure of the timeout argument is the number of system intervals." for the timeout parameter of os_evt_waits.
What is "system intervals", is it number of timer ticks?
Thanks.
This is a classic mistake of document authors - to use a term with a specific meaning, but fail to explicitly define that meaning!
You would have thought that it should be engraved on the forehead of every technical author by now - but, apparently, not.
It isn't even mentioned in the Glossary.
It is mentioned in an aside on this page:
www.keil.com/.../rlarm_ar_your_first_app.htm
"The RTX kernel starts a system timer by programming one of the on-chip hardware timers of the ARM processors. By default, the system interval is 10 ms and timer 0 is used (this is configurable)."
