Hai all, My program goes to infinite loop even though there is no while(1);
void main() { uchar8_t ISMCheckResult; CKCON=0x04; DR=1; delay(50000);//Power on delay for testing purpose enableLatch(0x00,0,7); delay(40); readBuffer(0,7); ISMCheckResult=IP_Sensing_check(); Display(ISMCheckResult); }
It stays in following Idata Loop....
IF IDATALEN <> 0 MOV R0,#IDATALEN - 1 CLR A IDATALOOP: MOV @R0,A DJNZ R0,IDATALOOP ENDIF
what is the problem? The functions in main I have used is very simple as follows...
void enableLatch(uchar8_t lactchValue,uchar8_t start,uchar8_t end) { uchar8_t index1; DR=0; for(index1=start;index1<=end;index1++) { XBYTE[latchAddressTable[index1]]=lactchValue; } DR=1; } void readBuffer(uchar8_t start,uchar8_t end) { uchar8_t index=0; DR=0; for(index=start;index<=end;index++) { Hardware_Buffer_Value[index]=XBYTE[bufferAddressTable[index]]; } DR=1; } uchar8_t IP_Sensing_check(void) { uchar8_t Flag=0,i; DR=1; for(i=0;i<INPUT_BUFFERS;i++) { if(Hardware_Buffer_Value[i]!=0) { Failed_Latch_Location[i]=ONE; Flag++; } else { Failed_Latch_Location[i]=ZERO; } } return((Flag>0)?ONE:ZERO); } void delay(uint16_t n) { uint16_t i; for (i=0;i<n;i++); } void Display(uchar8_t Input_Sensing_check_result) { uchar8_t index; SCON = 0x50; TMOD = 0x20; TH1 = 0xFA; TR1 = 1; TI = 1; DR=1; /* for(index=0;index<NO_OF_LATCHES_CHECK;index++) { printf("\nBuffer Contents %2bd %2bx\n",index+1,Hardware_Buffer_Value[index]); } */ if(Input_Sensing_check_result!=ZERO) { printf("\nChannel checking Failed\n"); for(index=0;index<NO_OF_LATCHES_CHECK;index++) { if(Failed_Latch_Location[index]!=ZERO) { printf("\nLatch/Buffer %2bx Failed\n ", index+1); } } } else { printf("\nChannel checking OK\n"); } }
The output is coming correctly but it goes to infinite loop as if while(1){ //functions} is used....what is the problem kindly clarify me..
Just a quick question - a program that exits main on a PC will either get back to the command line, or will have a nice GUI where you may start another program.
What will happen when a program exits main() on an embedded device, where there is no command line? Do you expect your processor to turn off, waiting for a reset or the download of new firmware?
By the way: Do not mix tab and space to indent your code. Spaces are better to use, since they don't rely on the viewing software (or web forum) to decide exactly how wide a tab is. Keep your code properly indented at all times.
Allowing an embedded program to exit main() is a fundamental error - the behaviour after exiting main() is undefined.
So whatever happens next is (probably) just a symptom of that fault.
You need to fix the fault, and not waste time speculating on the particular nature of the "undefined behaviour" that happens to occur in your case.
... and you're sure of that? I ask because your other description of the problem is much less specific:
What are the exact symptoms?
Oh, and what's the value of IDATALEN? Did you make any modifications to the startup code?
Buenos dias, Thanks for your time, I find the assembly precompiled routine interesting. a greeting from Juan Prieto.
