startup file add c-function
could you tell me how is it possible to include the At91F_LowLevelInit() function from Atmel in the startup file for the AT91RM9200 controller? The lowlevel-function (written in c) will init the sdram, clocks, flash memory and so on.
(short part of the startup file from Atmel, where the lowlevelinit function is called)
;-Low level Init (PMC, AIC, EBI, ....)
;- Add loop to compensate Main Oscillator startup time
        ldr     r0, =0x00000010
LoopOsc
        subs    r0, r0, #1
        bhi     LoopOsc
        IMPORT    AT91F_LowLevelInit
        ldr       r0, = AT91F_LowLevelInit
        mov       lr, pc
        bx        r0
When I use the startup file from Atmel with this init-function I'm able to start an application downloaded via xmodem in the internal RAM. When I use the startup file from Keil, I'm not able to reach the __main function within the startup file. I don't know why but it seems that the controller is not able to run the whole file supported by keil.
best regards
Hans
