I am new to STM32 and RTX, and i am following the example: Modify the device startup file to enable SWI_Handler function: Comment out the following line from the startup file: SWI_Handler B SWI_Handler
Add the following line to the startup file: IMPORT SWI_Handler
But this line is not present in the startup file STM32F10x.s
What do i need to do?
Kasper
STM32 is a Cortex-M3 device with completely different exception handling (SWI is replaced with SVC, ...).
You don't need to modify STM32F10x.s. It works by default with RTX.
Take a look at the RTX examples in the RealView MDK installation. Folder Keil\ARM\Boards\Keil\MCBSTM32, examples RTX_Blinky, RTX_Traffic.
Thank you for your answer.
I was trying this example from the documentation:
OS_TID tsk_1, tsk2_1, tsk2_2, tsk2_3; int cnt;
void task2 (void) __task { os_dly_wait (2); cnt++; }
void task1 (void) __task { /* This task will create 3 instances of task2 */ tsk2_1 = os_tsk_create (task2, 0); tsk2_2 = os_tsk_create (task2, 0); tsk2_3 = os_tsk_create (task2, 0); /* The job is done, delete 'task1' */ os_tsk_delete_self (); }
int main (void) {
os_sys_init(task1); for (;;); }
But when i in the simulator put a breakpoint on this line: cnt++; and runt the program, it breaks first time, but not again and it says that this task is overflow...
it seems like the processor comes to HardFault_Handler\
what do i do wrong?
Kasper aka neewbie
please use the 'pre' and '/pre' qualifiers to post code. I sounds like your task has too little stack space.
Hello Reppy Repzak,
A task needs always an endless loop. Without it get started and finishes at once. Create your task2 like:
void task2 (void) __task { while (1) { /* endless loop */ cnt++ ; /* increment counter */ os_dly_wait (10); /* wait for timeout: 10 ticks */ } }
Best Regards, Martin Guenther
Thanks...
I acutallu have readed that, strange they do not include in their examples.. maybe to keep them simple
