Firmware-Update via TCPNET
Hello.
I would update the firmware of my ARM7-board (AT91SAM7X256) over ethernet. The simplest way for the user is to open a browser and put the new firmware-file via POST to the board.
But IÂ've found in this forum (http://www.keil.com/forum/docs/thread8929.asp) that it isnÂ't possible to put files to the ARM with TCPNET.
How do you update your application (over ethernet; I have no other interface)?
If it is possible I want to use the http-server from Keil.
Thanks and wbr
Heiko
