I am using a licensed version of uvision. It used to be working fine, but since past few days it started giving me problem. it suddenly hangs when I am writing my code and then only way to get out of it is to close it and open it again. Sometime even after reopening it doesn't start properly. Then it again needs to be close and restart.
This problem occur always while I am typing my code or removing some lines using backspace. Any idea how should I get out of this problem? Any help in this regard is highly appreciated
In that case, you should contact Keil support.
I agree with Andy. This is a case for Keil Tech Support. But I remember a past history where the 'outlining' features and backspaces were not compatible. I tried my present version with no outlining problems. I'm presently running version 8.16a of the Keil tools. You failed to mention the versions of your tools. Bradford
My version is 8.05a. Actually this problem started coming since past few days before that it was working fine. @ Al-- Al which version you were facing problem with?
Have you tried looking at the list of updates for your software? 16E is the latest. Check the changes the problem you are experiencing may have been fixed already.
Stephen
