When i compile this code it give error like:-]
error 88: illegal cast of Literal value to 'generic' pointer from type 'literal-unsigned-char' to type 'unsigned-char generic*'
error 47:indirection to different types assignment from type 'literal-unsigned generic*' to type 'unsigned-char'
#include <8051.H> #include "Kernel.h"
#include "AVX.H" #ifndef IntSP #define xdata unsigned char * xdata IntSP; IntSP = (0xC0); #endif //--------------------------------------------------------------------------- Kernel data g_Kernel; //---------------------------------------------------------------------------
extern void Kernel_RestoreContext(); extern void Save_Stack(unsigned char idata *InternalSP, unsigned char xdata *ExternalSP ); extern void Restore_Stack(unsigned char idata *InternalSP, unsigned char xdata *ExternalSP ); extern void Init_Ram(); //--------------------------------------------------------------------------- void Kernel_ContextSwitch() { unsigned short data pc;
// Save return address. // Pop high byte of return address. *(unsigned char xdata *)&pc = *(unsigned char idata *)SP--;
// Pop low byte of return address. *((unsigned char xdata *)&pc + 1) = *(unsigned char idata *)SP--;
Save_Stack(g_Kernel.Tasks[g_Kernel.RunningTaskIndex].InternalSP , g_Kernel.Tasks[g_Kernel.RunningTaskIndex].ExternalSP ); // Save current Task's internal stack pointer. g_Kernel.Tasks[g_Kernel.RunningTaskIndex].InternalSP = ( unsigned char idata *)SP; // Save current Task's external stack pointer. // g_Kernel.Tasks[g_Kernel.RunningTaskIndex].ExternalSP = Kernel_GetXBP();
// Switch to next Task. // Round-Robin scheduling.
#ifdef PREEMPTIVE
r=LogTable256[taskRdyMatrixIndex]; c=LogTable256[taskRdyMatrix[r]];
priority = (r<<3) | c; // priority = 63 - priority; g_Kernel.RunningTaskIndex =taskRdyQue[priority];
#else
g_Kernel.RunningTaskIndex = (g_Kernel.RunningTaskIndex + 1) % g_Kernel.TaskCount; #endif
Restore_Stack(g_Kernel.Tasks[g_Kernel.RunningTaskIndex].InternalSP , g_Kernel.Tasks[g_Kernel.RunningTaskIndex].ExternalSP ); // Restore next Task's internal stack pointer. SP= (volatile unsigned char)g_Kernel.Tasks[g_Kernel.RunningTaskIndex].InternalSP; // Restore next Task's external stack pointer.
// Restore return address. // Push low byte of return address. *(unsigned char idata *)++SP = *((unsigned char xdata *)&pc + 1); // Push high byte of return address. *(unsigned char idata *)++SP = *(unsigned char xdata *)&pc;
// Note: ISR will restore next Task's all registers. } //--------------------------------------------------------------------------- void Kernel_Initialize() { #if 0 == OS_TASK_COUNT #error OS_TASK_COUNT can not be 0! #endif
// Initialize the kernel object. Init_Ram(); Initialise_Shell(); TaskCreate(Task_Idle,63, 0x6000); g_Kernel.RunningTaskIndex = 0; g_Kernel.TaskCount = 1; } //--------------------------------------------------------------------------- void Kernel_Start() {
r=LogTable256[taskRdyMatrixIndex]; // calculate highest priority task c=LogTable256[taskRdyMatrix[r]];
#else // roundrobin
#endif
*(IntSP) =(unsigned char*)(g_Kernel.Tasks[g_Kernel.RunningTaskIndex].ExternalSP);
(unsigned char*) *(IntSP + 1) =((g_Kernel.Tasks[g_Kernel.RunningTaskIndex].ExternalSP)+1);
// Restore next Task's internal stack pointer. SP =(volatile unsigned char ) g_Kernel.Tasks[g_Kernel.RunningTaskIndex].InternalSP; // Restore next Task's external stack pointer. start_timer(); // start the timer // Restore first Task's all registers. Kernel_RestoreContext(); } void start_timer() { // Setup timer. TMOD |= 1; // Interrupt per millisecond. TH0 = (65536 - 20000) / 256; TL0 = (65536 - 20000) % 256; ET0 = 1; TR0 = 1; // Enable all interrupts. EA = 1;
} //--------------------------------------------------------------------------- void Initialise_Shell(void) { TMOD|=0x20; // timer 1 mode 2 auto reload TH1|=0xFD; TL1|=0xFD; // baud 9600 SCON|=0x50; // 8 bit 1 top bin 1 ren enabled IE|=0x90; // enable serial interrupt TR1|=1; }
void Task_Idle() { while(1); }
---)))))))))------((((((((==========((((((++++++++++)))))))))))))))))___________
Kernel.h file
//--------------------------------------------------------------------------- #ifndef KernelH #define KernelH //--------------------------------------------------------------------------- #include <AVX.h> #include "Task.h"
void Task_Idle(); typedef struct _Kernel { unsigned char RunningTaskIndex; // Running Task index. unsigned char TaskCount; // Task count. Task Tasks[OS_TASK_COUNT]; // Task objects. } Kernel;
// Initialize the kernel. // Parameters: // None. // Return value: // None. void Kernel_Initialize(); // Context switch the kernel. // Parameters: // None. // Return value: // None. void Kernel_ContextSwitch(); // Start the kernel. // Parameters: // None. // Return value: // None. void Kernel_Start(); void start_timer(); void Task_Idle();
//--------------------------------------------------------------------------- extern Kernel data g_Kernel; //--------------------------------------------------------------------------- #endif // KernelH //---------------------------------------------------------------------------
HELP !
please re-post using the pre and /pre tags, and do add some clarifications...
Please read the instructions on how to post source code: www.danlhenry.com/.../keil_code.png
Please re-post your code, correctly formatted, in just one of your threads, and post a link in the other to the corrected version.
Be sure to check the formatting using the 'Preview' before you post!
Also, try looking-up those error messages in the Manual:
http://www.keil.com/support/man/docs/c51/c51_errors.htm
