uVision 3 and ATOCD51
I'm trying to set up the Atmel ATOCD51 as a emulator in uVision. I installed FLIP as directed and the driver for uVision. When I started the debugger in uVision it stated that I needed to update the firmware in the ATOCD51. I let that process run but it failed. I went to the directory where UPDATE_FIRMWARE.BAT is located and ran it from there. It was successful.
When I tried to load the binary; Device selection, Hardware selection and Opening port all pass. Inializing OCD produces a message box that says, "Unknown OCD target; possible targets are: R51, C51, M51, LINK and LP."
On a lark I recompiled the project and tried to load it again. As before; Device selection, Hardware selection and Opening port all pass. This time, however, I get a message box that says, "Debug command sent. Did not get the OCD prompt."
In Project Utilities I have selected "Use External Tool for Flash Programming". The Command is set to: "C:\Program Files\Atmel\Flip 3.3.1\bin\batchisp.exe" and Arguments is: "-device ATOCDTARGET -hardware RS232 -port COM10 -baudrate 19200 -ocd 51 -operation memory 14 loadbuffer %H PROGRAM".
I've tried this with both the new project PCB and an Atmel AT89STK-11 demo board with the same results.
Atmel's response was to use batchisp.exe instead of FLIP. That was less than useful since I am using batchisp and not FLIP.
Sorry this is so long but I'm totally confused that this point as to what to try next.
Thanks for any direction.
Bill
  • Have you tried "-device ATOCDTARGET -hardware RS232 -port COM10 -baudrate 19200 -ocd C51 -operation memory 14 loadbuffer %H PROGRAM" rather than "-device ATOCDTARGET -hardware RS232 -port COM10 -baudrate 19200 -ocd 51 -operation memory 14 loadbuffer %H PROGRAM"?
