Does anyone know what the cost of the electricity is to recharge 12volt lead acid battery.
regards Bill
it be depending to the capacitey of teh battary you be not knowing yes.
you be say who is teh capecitey and we be giving you a good answer yes.
is you be thinking to write code at keil with it?????
I would guess that you could figure it out given the number of amp hours in the battery, the voltage and compute the watts for that. Then take your cost of electricity in kw and compute the result.
This of course has nothing to do with C compilers, so I wonder why you would ask this question, but I'm not a flamer so I won't roast you for it. Cheers Scrungy
Thanks scrungy, I suppose I should do the math. reason for Q, i repair golf trolleys and have about 10 battteries on charge at a time. Cost of leki going through roof. bit on the slow side what is a flamer.
Bill
A flamer is someone who gets bombastic and sarcastic and verbally runs you down. It doesn't take much to set some people off. All you have to do is look through some of these threads some examples here is the last lead acid battery question.
http://www.keil.com/forum/docs/thread12851.asp
and here is a good example of flaming. http://www.keil.com/forum/docs/thread12948.asp Per Westermark is not being very nice
http://www.keil.com/forum/docs/thread13003.asp
Cheers
I think you will have to update your definition of a flamer.
First link: I do not belive that you intended me as flamer there, for answering the OPs questions, so you must mean Andy's subject line: "And the nominations for the "Most Wildly Off-Topic Question" award are..."
Second link: The discussion starts with a hijack of another thread, and without relevant facts for anyone to answer. The discussion continues in the linked thread a number of days later, where the previous thread hijacker has suddenly gotten in a hurry to get a set of implemented functions, based on a request that still doesn't contain the relevant information for anyone to answer.
It is always considered bad to try and force forum members to hurry to answer questions.
There is a big difference between asking a question after getting stuck, and writing posts with need/give me/now/urgent/send requests.
Note the questions/suggestions I wrote in my second post? Flamers don't give suggestions - other than of the unprintable kind.
Third link: Tamir oposes to a thread hijacker who are SCREAMING and asking about ARM information in someone elses C51 thread - and then gives advice.
Well, this question certainly does look like a pretty strong contender...
I think this would be a more appropriate place to look: www.maplin.co.uk/Module.aspx monitor&doy=26m8
(you're going to have to manually copy-and-paste that link)
