Hi, The linker BL51 generates this error: *** FATAL ERROR L228: RAMSIZE PARAMETER OUT OF RANGE I workunder silicon labs ide, has someone an idea how to parameter the Ram, and where ?
Thx
It is likely that you used more memory than you have on your board.
Take a look at http://www.keil.com/support/man/docs/bl51/bl51_ramsize.htm
Jon
Ok,thx. I have solved the problem
