I cant get the right input form port 1. My program waits until a button is pushed and then executes some code.
the program itself works fine when i use port 0 but i I'm working on a dev board and i need the port 0 to communicate with the onboard devices. So i want to use port 1 for my push buttons and leds.
PINSEL0 = 0; //set port0 to IO PINSEL1 = 0; PINSEL2 &= ~0x0000000C; //set port 1 to IO PINSEL2 |= 0x00000030; DelayProc(0.2 * CCLOCK); //delay IO1DIR = 0x00FF0000; //16->23 output; 24->31 input; //wait until push while((IO1PIN & 0x01000000)!=0x01000000); //leds 1.16 to 1.23 on; IO1SET = 0x00FF0000; //end of demo.
the leds work but the button doesn't. it is like the button is always pressed.
could anyone give me some advise on how i could use port 1 as input?
I don't know your device - can it be that you have a bit somewhere to distinguish between fast and slow GPIO for port 0...? that is implemented on the LPC2478.
its the lpc2148 processor i use on the easy arm development board.
