Hi all,
I have used malloc in my application code. LPC2138 is the processor & GNUARM7 is the compiler. while running the code the global variables had been changed at the execution of free() function. Give me the solution for this.
Regards, yos
See: http://www.keil.com/forum/docs/thread12738.asp
i didn't get the exact answer from you.I have to use malloc inside the interrupt routine. would u pls give me the solution ?
The exact answer is that this is not the (best) place to discuss GCC issues - it's a Keil forum.
"use malloc inside the interrupt routine"
Irrespective of what tools you use, that sounds like a Really Bad Idea...!!
=:0
"give me the solution ?"
Don't do that!
