I m looking for a test bench/compiler/add-on that will help me import some functions(modules) that I have written for keil ( c program) and compile in VC++.
Precisely this is what I want to do: I have a function that uses lot of SFR's and bit variables.Now I want to test the function. But I don't want to run it on any hardware or test it in a debugger. Instead I want to give this module as input to a script that generates lot of various possible combination's of input and provides to the function. Assume there are not any hardware/interrupt related operations necessary.
Problem: bit variable handling is ok.. but when it comes to sbit... it becomes tedious;
assume I have a bit variable defined as 6th bit of some byte variable I can always carry AND or OR operation on the BYTE and still the bit will get affected.
How to simulate this behaviour in VC++. how do i define a bit and then make it part of byte variable.
You are going to have to write some preprocessor macros, and take care to only ever access your bit-addressable objects via these macros.
Then you can have the macros expand to C51 bit & byte access, and some other scheme in VC++...
You should be able to use standard 'C' bitfields in VC++...?
Thanks Andy, Never thought about bit fields, Thanks for the pointer,
Regards, John
