I have a problem running USBMem code from the Keil example with Nohau LPC2800 Evaluation Board. When I connect the board with my pc running with Open SUSE 10.3 x86_64 bit system. It give this error:
new high speed USB device using ehci_hcd and address 4 device descriptor read/8, error -71 new high speed USB device using ehci_hcd and address 5 device descriptor read/all, error -71
But when I remove the ehci_hcd mod from my pc, it will run fine with full speed.
Is there any way I can make it run without remove ehci_hcd mod?
When I check the USBIntStat of USBMem while running, it prints out 0 ( which is for low speed) can anyone know how to make USBMem run at high speed? The USBMem code is at C:\Keil\ARM\Boards\NOHAU\LPC2800\USBMem.
Thank you,
Tho
