Error 65 access violation
Hi im having a problem with the interrupts im making a mastermind game that uses a matritial board 4x16 and im using a changin bit to check if any button has been pressed, and everything goes right until the second interrupt ooccurs, the changin bit stops, im using timer 0 to generate this ive checked the interrupt enables and everything is all right the error is:
error 65: access violtion at C:0x3A29 : no execute/read permission ill appreciate any help! if you cna reply to my email better
thanks
jimmy098@gmail.com
