using PCA FOR baud rate generation i am acing problem
HEllo we are using silabs c8051f340 controller.we try to implement software uart using programle counter arrays(PCA)for baud rate generation and i am not able get to desired baudrate .we are using internal clk of 12000000 and baudrate is 9600 please try to give sloution
  • void UART0_Init (void)
    { SCON0 = 0x10; // SCON0: 8-bit variable bit rate // level of STOP bit is ignored // RX enabled // ninth bits are zeros // clear RI0 and TI0 bits if (SYSCLK/BAUDRATE/2/256 < 1) { TH1 = -(SYSCLK/BAUDRATE/2); CKCON &= ~0x0B; // T1M = 1; SCA1:0 = xx CKCON |= 0x08; } else if (SYSCLK/BAUDRATE/2/256 < 4) { TH1 = -(SYSCLK/BAUDRATE/2/4); CKCON &= ~0x0B; // T1M = 0; SCA1:0 = 01 CKCON |= 0x09; } else if (SYSCLK/BAUDRATE/2/256 < 12) { TH1 = -(SYSCLK/BAUDRATE/2/12); CKCON &= ~0x0B; // T1M = 0; SCA1:0 = 00 } else { TH1 = -(SYSCLK/BAUDRATE/2/48); CKCON &= ~0x0B; // T1M = 0; SCA1:0 = 10 CKCON |= 0x02; }
    TL1 = TH1; // init Timer1 TMOD &= ~0xf0; // TMOD: timer 1 in 8-bit autoreload TMOD |= 0x20; TR1 = 1; // START Timer1 TI0 = 1; // Indicate TX0 ready
  • 5 points for unreadable code.
    What was wrong with posting the code according to the Keil instructions? Would that have made the code too easy to read?
  • Wow that came out to one line this is kind of what it was supposed to be I think.
    // RX enabled
    else
    CKCON |= 0x09;
    else
    CKCON &= ~0x0B;
    else
    CKCON &= ~0x0B;
    CKCON |= 0x02;
    TMOD |= 0x20;
    Dubious translation caveats added.
    Stephen
