programming of 12 channel temperature scanner
sir can you give me the programming of 12 channel temperature scanner i can't understand what to do.. plz help me... thanks
mital
  • The best recommendation is that you talk with your teacher.
    You may already have received information about what sensors to use. 12 analog sensors to a multiplexed ADC. Or 12 I2C or Dallas one-wire sensors. Or maybe 12 pulse-length-encoding sensors.
    The type of sensor will decide the next required steps.
    But the first three steps: Read datasheet for temp sensor(s). Read datasheet for processor. Once more read project description.
