I need help with FS_ARM_L.lib in code example for RL-ARM MMC/SD file demo for MCB2300. When I open the project, the library is not found. I have searched for this file via Google without any success.
try .\Keil\ARM\RV31\LIB
The FS_ARM_L.lib is a part of RL-ARM. It does not exist in MDK.
There is a note: NOTE: DO NOT RECOMPILE THE EXAMPLE WITHOUT RL-ARM LICENSE!
http://www.keil.com/download/docs/338.asp
ho, I did not realize the OP does not have a license...
So with the demo licence you cannot use this example?
I think the thing is that you can use the demo as-is, but you cannot rebuild it?
There is similar file RTX_ARM_L.lib in LIB directory but no FS_ARM_L.lib
