str910 Vs STR-E912 difference
Hi all,
previously I was working on STR-E912 based board it has the processor STR912FW44Xb the code which was working fine on that bord was also working fine on the board STR-910-eval which has processor STR912FAW47X6 but when I interchanged STR912.s files the code was not working on STR910 can you please tell what exactly is the difference between two processors?
