Problems degugging
Hi everyone,
I have the following problem.
When I connect ULINK2 to my XC164CS starter kit board through JTAG debugger, I download a simple program, I can start debugging with no problem, it means that, the cursor is situated at the fist instruction of "main" and everything works well.
But when I try to do the same with my designed board (Downloading the same program) the debugger is executed as "run", when it should debug step by step. Therefore, I can do nothing. Is ULINK2 configuration problem?
What can be the problem?
Thank you very much.
