ARTX166 and Infineon XE167 not working
Is there anyone with experience with the ARTX166 RTOS and the
Infineon XE167. I have problems to get the RTOS working which is caused
by the interrupts of the used timers. The interrupt never com and all
RTOS functions with a delay hangs. Although the webpage of Keil
tells the RTOS is compatible , the RTOS is not for the XE167.
I had made a report of this bug to Keil but they never answer me when
a update of the RTOS comes. They have commit that there is problem
with the XE167 and the use of ARTX166 but still there is no solution.
Maybe there is ARTX user who have a work around for this and
can give me some information how to get the RTOS running.
  • I have no experience with XE167 or ARTX166, but I could guess that the problem is the difference in XC167 vs. XE167 timers and interrupt vectors.
    Let's suppose that you let ARTX use the default timer T0. There is no such timer in XE167 (at least I didn't find it after a quick look at the User Manual). Naturally this leads to no timer interrupt. You could try this workaround: Configure ARTX to use timer T0, which puts the ARTX timer tick interrupt vector at location xx0080H. In XE167 this location contains timer T2 interrupt vector. After starting up ARTX, initialize timer T2 to interrupt at the desired ARTX tick rate.
    Even if you manage to get the ARTX tick running this way, you may still run into trouble if ARTX for any reason needs to manipulate the timer after the initial setup.
  • Thanks for your response Sauli.
    I discoverd that if i make a copy of the interrupt
    handler ( made with the Infineon Dave tool ) and place
    a copy in the AR166_Config.c on line 345
    Replace :
    void os_clock_interrupt (void) interrupt OS_TIMER_INT = OS_INTNR
    Replaced by: void GPT1_viTmr2(void) interrupt T2INT
    Initialisation of TMR2 is now done by the generated function void GPT1_vInit(void)
    It looks the sytem works if Timer2 is used
    but not if the original init of the RTOS is used.
    I think Keil have to made some modifications on the initialisation of the Timers ( just you suggested )
    for the RTOS.
    Maybe there are some more modifications need in the
    ARTX166 of Keil but this has te be done by the
    Keil company where my company purchased the compiler and RTOS for a lot of money.
    Any way thanks for your response.
  • Problem found interruptvector in AR166_CONFIG.C
    was not o.k. for the Infineon XE167.
    Infineon XE167 has also less Timers.
    Modification of AR166_CONFIG.C for XE167
    #if (OS_TIMER == 2)/* Timer2 */
    #define OS_TREG T2
    #define OS_TOVF T2IR
    #define OS_INTNR 0x20 // <== was 0x22
    #define OS_TIE T2IE
    #define OS_TRUN() T2CON = 0x0040
    #define OS_TIEN() T2IC = aINT_ENABLE
    #define OS_TSET() T2 = OS_TRV
    #define OS_TREL() T2 += OS_TRV
    #elif (OS_TIMER == 3)/* Timer */
    #define OS_TREG T3
    #define OS_TOVF T3IR
    #define OS_INTNR 0x21 // <== was 0x23
    #define OS_TIE T3IE
    #define OS_TRUN() T3CON = 0x0040
    #define OS_TIEN() T3IC = aINT_ENABLE
    #define OS_TSET() T3 = OS_TRV
    #define OS_TREL() T3 += OS_TRV
    #elif (OS_TIMER == )/*Timer4*/
    #define OS_TREG T4
    #define OS_TOVF T4IR
    #define OS_INTNR 0x22 // <== was 0x24
    #define OS_TIE T4IE
    #define OS_TRUN() T4CON = 0x0040
    #define OS_TIEN() T4IC = aINT_ENABLE
    #define OS_TSET() T4 = OS_TRV
    #define OS_TREL() T4 += OS_TRV
    #elif (OS_TIMER == )/*Timer5 */
    #define OS_TREG T5
    #define OS_TOVF T5IR
    #define OS_INTNR 0x23 // <== was 0x25
    #define OS_TIE T5IE
    #define OS_TRUN() T5CON = 0x0041
    #define OS_TIEN() T5IC = aINT_ENABLE
    #define OS_TSET() T5 = OS_TRV
    #define OS_TREL() T5 += OS_TRV
    #elif (OS_TIMER == 6)/* Timer 6 */
    #define OS_TREG T6
    #define OS_TOVF T6IR
    #define OS_INTNR 0x24 // <== was 0x26
    #define OS_TIE T6IE
    #define OS_TRUN() T6CON = 0x8041
    #define OS_TIEN() T6IC = aINT_ENABLE
    #define OS_TSET() T6 = CAPREL = OS_TRV
    #define OS_TREL()
    #else
    #error OS_TIMER invalid
    #endif
  • Did you remember to tag your code as code?
  • I'am sorry first time i post a message here
    But i learn fast.
    Next piece of code must also be added to get
    the RTOS working..........
    // add define's to AR166_CONFIG.C //
    #ifndef GPT12E_KSCCFG
    #define GPT12E_KSCCFG   (*((unsigned int volatile *) 0xFE1C))
    #endif
    #ifndef SCU_SLC
    #define SCU_SLC         (*((unsigned int volatile *) 0xF0C0))
    #endif
    #ifndef SCU_SLS
    #define SCU_SLS         (*((unsigned int volatile *) 0xF0C2))
    #endif
    // add lock and unlock functions to AR166_CONFIG.C //
    void AR166_vUnlockProtecReg(void)
      unsigned int uwPASSWORD;
        SCU_SLC = 0xAAAA;                   // command 0
        SCU_SLC = 0x5554;                   // command 1
        uwPASSWORD = SCU_SLS & 0x00FF;
        uwPASSWORD = (~uwPASSWORD) & 0x00FF;
        SCU_SLC = 0x9600 | uwPASSWORD;      // command 2
        SCU_SLC = 0x0000;                   // command 3
    } //  End of function MAIN_vUnlockProtecReg
    void AR166_vLockProtecReg(void)
        SCU_SLC = 0x1800;                   // command 3; new PASSWOR is 0x00
        SCU_SLC = 0x8E00 | uwPASSWORD;      // command 4
    } //  End of function MAIN_vLockProtecReg
    // Modification of os_tmr_init in file //
    // AR166_CONFIG.C //
    /*--------- os_tmr_init  -------*/
    void os_tmr_init (void) {
      AR166_vUnlockProtecReg();
      GPT12E_KSCCFG = 0x0003;  // enable  module
      _nop_();
      _nop_();
      AR166_vLockProtecReg();
      OS_TSET();
      OS_TIEN();
      OS_TRUN();
    #if (OS_ROBIN == 1)
       os_robin_time = OS_ROBINTOUT;
    #endif
    } /* end of os_tmr_init */
