Yesterday I received an EK-LM3S8962 evaluation board and wanted to use it with the uVision3 V3.62c that I downloaded last week. However, after flashing the application the debugger is unable to load the AXF file and stops with the following error:
Error: Could not load file 'xxx.AXF' Debugger aborted !
I have no issues with the EK-LM3S811 board I have.
I've tried it with uVision V3.60e that came on the CD of the kit and there it works.
Any idea what could be going wrong?
Please find below the info of both uVision3 versions.
Thanks,
Ronald
*** DOWNLOADED KEIL INFO ***
IDE-Version: µVision3 V3.62c
Tool Version Numbers: Toolchain: RealView MDK-ARM Version: 3.22a Toolchain Path: \BIN31\ C Compiler: Armcc.Exe V3.1.0.934 [Evaluation] Assembler: Armasm.Exe V3.1.0.934 [Evaluation] Linker/Locator: ArmLink.Exe V3.1.0.934 [Evaluation] Librarian: ArmAr.Exe V3.1.0.934 [Evaluation] Hex Converter: FromElf.Exe V3.1.0.934 [Evaluation] CPU DLL: SARMCM3.DLL V3.22a Dialog DLL: DLM.DLL V1.14 Target DLL: BIN\lmidk-agdi.dll V??? Dialog DLL: TLM.DLL V1.14a
*** EVALUATION CD KEIL INFO ***
IDE-Version: µVision3 V3.60e
Tool Version Numbers: Toolchain: RealView MDK-ARM Version: 3.20c Toolchain Path: BIN31\ C Compiler: Armcc.Exe V3.1.0.925 [Evaluation] Assembler: Armasm.Exe V3.1.0.925 [Evaluation] Linker/Locator: ArmLink.Exe V3.1.0.925 [Evaluation] Librarian: ArmAr.Exe V3.1.0.925 [Evaluation] Hex Converter: FromElf.Exe V3.1.0.925 [Evaluation] CPU DLL: SARMCM3.DLL V3.20c Dialog DLL: DLM.DLL V1.13 Target DLL: BIN\lmidk-agdi.dll V??? Dialog DLL: TLM.DLL V1.13
Thanks to the wonderful support of Luminary I got pointed to this article:
http://www.keil.com/support/docs/3411.htm
I've recevied the new TLM.DLL file today, didn't test it yet though.
gr.
