Hi all,
I want to use the bootloader from St (AN2475). I can download and write files to flash only if the size does not exceed 8K. As soon I want to write the flash bank1 on a location passed the 8K, I get verifaction error when comparing data. The data in flash is always 0xFFFF (erased).
Device is STR912FA44 revision 'H'.
Does anybody has this bootloader running, or can anybody give me some advise ?
Thanks.
Hello Luc Vercruysse,
Maybe Support knowledgebase article http://www.keil.com/support/docs/3429.htm helps you.
Best Regards, Martin Guenther
Thanks for reply. However, I do not think that is my problem because the application does not run outside the debugger as well. I have found out something as you can see here www.st.com/.../forums-cat-7845-21.html
