I am trying to calculate a simple checksum on my code. I am doing something like this:
unsigned short Index, Checksum = 0; unsigned char code * data pCode = 0; for( Index = 0; Index < end_of_code; Index++ ) { Checksum += *pCode++; }
How can I get the linker to fill in the 'end_of_code' address or the size of the code segment?
Thanks, Dan
At least the LX51 linker has a directive to put a given segment to the very end of the code. Use it on a dedicated (assembly) file holding only the end_of_code symbol.
Try this...
http://www.keil.com/support/docs/2681.htm
--Cpt. Vince Foster
Some Linkers do provide symbols which allow the software to gain information like this.
It is a frequently asked question on this forum, and Keil have gone to the trouble of writing an article about it.
So why not just build it into the linker, then?! Clearly the demand exists...
I tried the suggestion at:
but that didn't place the module at the end of the code segment. It turns out that I was running into the same problem that Hans-Bernhard ran into concerning gaps (see http://www.keil.com/forum/docs/thread5659.asp). Once I made the variable an array that was larger than the gap, it was placed at the end of my code. Not really a good solution since every time I build, I'll have to make sure that the linker didn't make the gap larger and place the end of code marker in it.
I agree with Andy - why don't they just make the linker assign a special symbol that represents the end of code?
"why don't they just make the linker assign a special symbol that represents the end of code?"
See: http://www.keil.com/forum/docs/thread12128.asp
