Hello, I'm using Keil MCBSTM32 evaluation board and µVision3. I use the example CAN program downloaded from keil. My application will be to use an external rotational transducer (instead of the potentiometer on the board) to send converted analog value in CAN message. Which code should i change/add so that i could use the transducer (at port A chan 0 for example) instead PA ch 1 of the pot? I've read the reference manual from ST but i didn't see any indication telling which registers correspond to which channel to use. Thank you in advance.
all you need to do is slightly modify your ADC configuration. are you sure it does not appear in the reference manual?
ADC->CR |= 0x0033; /* cont. conversion all channels */ ADC->CCR |= 0x00FF; /* ADC, no WDG, Channel 0..4 */
works for the STR9. does this help?
In STM32's control register they're ADC_CR1 et ADC_CR2:
In CanDemo.c:
ADC1->CR1 = 0x00000100; // use independant mode, SCAN mode
ADC1->CR2 = 0x000E0003; // data align right, cont conversion
In ADC_CR1 however there's AWDCH[4:0]: Analog watchdog channel select bits. Is that it? i dont wanna use watchdog though.
Thanx!
I don't know. I am not familiar with your processor, but the data sheet is. it must be there!
Thanx for ur reply, i think i figured it out how to get my sensor to work in PA CH0. Anyway, is there anyway easy to generate an error? my application would be quite simple: i want to demonstrate a CAN communication - interfacing the sensor to stm32 and get to see the communication (the frames) preferably at my PC. the µVision3 simulation able to do that? or do i need to use a CAN Analyser like for example ValueCAN (intrepidcs.com/.../35) for that purpose?
as far as I know, you would require a CAN sniffer of some kind.
maybe this helps: http://www.keil.com/download/docs/373.asp
Hello Ferris Adna,
to use PA0 instead of PA1 change the code as follows:
RCC->APB2ENR |= RCC_APB2ENR_ADC1EN; // enable periperal clock for ADC1 ADC1->SQR1 &= ~0x00F00000; // only one conversion ADC1->SMPR2 &= ~0x00000007; // clear bits 0..1 (channel0) ADC1->SMPR2 |= 0x00000005; // sample time (55,5 cycles) ADC1->SQR3 = 0x00000000; // set channl0 for 1st conversion ADC1->CR1 = 0x00000100; // use independant mode, SCAN mode ADC1->CR2 = 0x000E0003; // data align right, cont conversion // EXTSEL = SWSTART // enable ADC, no external Trigger ADC1->CR2 |= 0x00500000; // start SW conversion
Best Regards, Martin Guenther
Thank you Reinhard Keil and Martin Gunther for your reply.
The link does help a lot.
Thanks Martin for the codes to use PA0 instead of PA1. I did that too and it worked.
