Analog Devices provide a lib file for its aduc841 MCU. I download the file from the following URL:
ftp.analog.com/.../841c_lib.zip
However, after I add the lib file to project source group, I get a message "bad or invalid library" when I try to check "options for file "aduc841.lib"". The response from ADI support is "maybe your keil had some problem". I'm using uVision V3.60.
Please help me with the issue. Thank you very much.
