respected sir this is my code
int main (void) { SYS_TargetResetInit(); PCONP |= (1 << 8); /* by default, it's enabled already, for safety reason */ PINSEL0 |= 0xC0000000; PINSEL1 |= 0x0000003C; S0SPCCR = 0x8; S0SPCR = 0x000; }
void SYS_TargetResetInit(void) { SCS |= 0x20; /* Enable main OSC */ while( !(SCS & 0x40) ); /* Wait until main OSC is usable */ CLKSRCSEL = 0x1; /* select main OSC, 12MHz, as the PLL clock source */ PCLKSEL0 = 0x55555555; /* PCLK is the same as CCLK */ PCLKSEL1 = 0x55555555; SYS_GPIOResetInit(); }
I don't have the data sheet for your processor in front of me, but S0SPCCR is clock control register? S0SPCR is control register?
Where do you write to the data register?
You're not going to get clock pulses if you are not writing data.
ND
Hi!
Are you sure, that you've enabled the SPI-Interface?? (PCONP-Register @ p.53 in Manual)
yes S0SPCCR is clock control register i use SOSPDR to WRITE the data
then also I am not going to get clock pulses
i given 12mz to procesor and that to the peripheral iinitialise all register as per above code but no sck getting .
