ADuC814 ... printf usage disables DAC usage ??
Im testing the uVision3 v8.16 IDE in connection with
ADIs original ADuC814 eval board. When driving the
DACs, everything works as long as IÂ'm NOT using
printf.
Does printf reset the DAC settings or something
like this ?
I inserted a condition so that fprint gets first used
after some time, it works the first time until printf
is used the first time, so i assume it is printf and
not global stdio that does the effekt
Please see the small example below. When removing the
printf command DAC0 will correctly output a sawtooth
wave but not anymore when the printf is included
#include <stdio.h>
#include <REG52.H>
sfr PLLCON = 0xD7; // PLL CONFIGURATION BYTE
sfr DACCON = 0xFD; // DAC CONTROL REGISTER
sfr DAC0L = 0xF9; // DAC0 DATA
unsigned char Output;
void main(void)
PLLCON = 0x00; // CPU 16.0MHz Clock
DACCON = 0xFF; // set both DACs: on, 08bit
while (1)
DAC0L = Output; Output++;
printf("%02bX \n",Output);
  • So what, exactly, does it do with that printf in there?
    You don't seem to have anything to control the timing of your output other than the time it takes to execute the loop.
    Obviously, printf - just like any other function - will take a certain time to execute.
    Obviously, therefore, adding printf - or any other function call - in your loop will affect the output.
    Is your serial output implementation polled, or interrupt-driven?
    Does the printf output appear correctly?
  • The program fragment I posted is part of a bigger code
    that does ADC and DAC interrupt driven. In the main
    loop I do nothing but just some printf output. I
    shrinked the code just to demonstrate the problem.
    I have NO problem that printf basically takes quite a
    long time to execute, I just have a problem with the
    fact that after the first time printf is used my DAC
    output is "dead". Before the first printf the DAC
    output worx, even with the bit code I posted. I also
    tried to re-setup the DACCON again but it doesnt help.
    I dont know if my serial output implementation polled or interrupt-driven, I guess polled, I did no setup
    for that since it worked fine just "out of the box".
    The printf output appears correctly. How is printf
    done when one does just a main(){printf("test")} ??
  • Problem was solved by shifting baudrate generation
    from T1 to T2.
    New problem - fitting to the headline : when using
    simple putchar in the main loop there is no problem
    but when using fprint instead the mentioned I/O
    interrupt is slowed down significantly.
    I have an interrupt several hundert times a second
    reading and writing external I/O and it works fine.
    The main program is just supervising stuff and putting
    it out on UART.
    Is printf or sub-parts of it disabling interrupts
    during runtime ? As far as I have read printf is also
    just using putchar so there should be no such problem,
    right ?
    I basically dont care how long printf needs to put
    stuff out since main things happen in the interrupt.
    So there is no execution time problem for me using
    printf, if it wouldnt slow down my I/O interrupt
    My tests show that cycles inside printf definately
    slow down the my I/O interrupts. When I shorten the
    printf statement, the I/O interrupt gets called more
    often than with a long printf statement.
    Strange. Any ideas ? I guess the printf source is not
    open, isnt it ??
