Hi tell me anyone how to use the hardware i2c in lpc2148 . Please give any sample example
help
Was there any problems with the documentation and sample code that is available from NXP?
Where did you get stuck?
Probably just that it would require some effort on the OP's part to read it & understand it?
But there's the rub: any other code supplied by anyone else is also going to require effort to read & understand!
The rub here is probably that it takes about 15 seconds, to enter "nxp" "source code" and "i2c" into Google and then get a link to application note an10369.pdf or possibly their source-code bundle.
These 15 seconds are to valuable to spend searching, so it is always better to ask on a forum and request someone else to search.
That a forum request may take several days to get processed while Google will produce results within seconds is an unimportant fact, better to ignore.
