different port manipulation in one function
Hi :
Take a look at this function
  sbit a=P0^1;
  void manipulate_port()
    a=1;
    Delay();
    a=0;
    Delay();
    a=1;
    Delay();
    a=0;
In above code, the hardware(P0.1) is manipulated in the function manipulate_port(); Now I want to manipulate one of the pins of PORT0 according to different parameter. I can program eight different process with eight different pin manipulation and then select which process to be executed by a parameter. But I donot think it is a properly method. Should I only use one process to complete such goal.
Because the manipulation is fixed(no matter which pin is use) So shall I program the process in such way.
  sbit a0=P0^1;
  sbit a1=P0^2;
  sbit a7=P0^7;
  void manipulate_port(uchar x)
    // according different x, the a will be point to   different pin,then execute the following
    a=1;
    Delay();
    a=0;
    Delay();
    a=1;
    Delay();
    a=0;
Is this resonable(or is this idea will be supported by keil)? If so ,how can I do it.
Thanks for your replying.
Jason Liu
