Does uvision/ulink2 have the ability to program stand-alone hex or bin files into dev boards via Jtag?
I can download and program files which are project-based, and I would expect there to also be a way to handle file images (hex, bin) which have no associated project, or at least a way to create a dummy project but use an unrelated file image for the actual download.
I see there are already several posts explaining how to do this under 'hex file', 'flash programming'.
http://www.keil.com/support/man/docs/uv3/uv3_fl_hexdownload.htm
