Hi!
I had inicialize RTC and it's work fine. Than I tested some other example and then I flash again first program with RTC and didn't work.
I'm using MCB2300 with LPC2378.
My inicialization
void RTC_init() { RTC_AMR = 0; RTC_CIIR = 0; RTC_CISS = 0; RTC_CCR = 0x00000010; // 32kHz osc RTC_PREINT = PREINT_RTC; //0 RTC_PREFRAC = PREFRAC_RTC; //0 RTC_CIIR |= 0x0001; //sec irq VICVectAddr13 = (unsigned long)rtc_irq; VICVectCntl13 = 10; //priority VICIntEnable |= 1<<13; RTC_CCR|=0x00000001; // RTC enable }
It could be a problem, that at start of procesor the most of registers are not init - have old values and have to be set? I looked all registers, but I didnt find nothing.
Thanke for your help
Peter
Have anyone some easy example for this bord with sending time on LCD or COM?
I'm realy desperate.
I have HW problem. The code was tested on another bord and works.
by
Does the 32kHz crystal oscillate?
No.
On VBAT pin is 3.1V, thats good. I will change oscillator and if will not be good, I will change CPU.
