Need explination of these two decloration software lines
What do the following lines do? Generaly not specificaly.
What do the terms mean/and or do? 1) xdata * xdata mean? 2) s_pSIN = (MASTER_2_AFPU*)&s_SIN;
static xdata uchar s_SIN[sizeof(MASTER_2_AFPU)];
static MASTER_2_AFPU xdata * xdata s_pSIN = (MASTER_2_AFPU*)&s_SIN;
  • Note that you can have a pointer that are stored in xdata memory.
    And you can have a pointer that points to an object stored in xdata memory.
    And then you can have a pointer stored in xdata memory, and pointing to an object in xdata memory. Hence the need for one xdata attribute before, and one after the star.
  • For question 1, please do consult the C51 manual. 'xdata' is a language extension, and you really have to study the documentation thoroughly to use it.
    As to what this:
    does: this is a somewhat silly detour for defining a pointer to an object of type MASTER_2_AFPU. s_SIN is a buffer of the right size for such an object, but of the wrong type. s_pSIN is meant to access that space as if it were of type MASTER_2_AFPU.
    Whether or not this code is correct or not depends on the unknown definition of MASTER_2_AFPU. If that's anything else but a an array of unsigned char itself, the code is sick.
  • Do you have a referance for xdata?
    This is a piece of contracted software that I suspect that the authors purposely making it obscure what are your thoughts? I appreciate your answer thank you very much.
  • This is a piece of contracted software that I suspect that the authors purposely making it obscure what are your thoughts?
    "Don't attribute to malice what can properly be explained with negligence."
    It's not all that obscure - if the author really wants to obscure the code, then he's doing a really poor job at it.
    It looks more like whoever wrote this is single-mindedly following conventions without considering if they make sense in the current context.
    What kind of reference ? What the keyword xdata does ? That is explained, in great detail and with examples, in the C51 compiler manual.
