Hi all,
I start a design on STR912FAW44 and I'm using CAPS software (ST) to assign pins. But I've a problem to declare I2C0 as master. I2C0 on P2.0 and P2.1. I check registers values generated in conf.h file :
#define GPIOIN2 0x1 #define GPIOOUT2 0x8 #define GPIO_DIR2 0x0
I don't understand why P2.0 is set as I2C0_CLKIN and P2.1 as I2C0_DOUT ? And why GPIOIN register set only P2.1 as output ? One pin as input and other as output ??
How can I declare I2C0 master mode with the 2 pins as ouput (2C0_CLKOUT and I2C0_DOUT) in CAPS ?
Thanks in advance
In that case, shouldn't you be asking ST about their software...?
Yes, one week ago, but not yet answer. I think maybe someone from here know this problem ??
