FLASH loading thr' the JTAG port
I am using keil uvision3 with ULINK2 adaptor.
I am using 10 pin connector from ULINK2 to my PCB.
I have checked the connections for JTDI,JTDO,JTMS,JTCK,JTRST,VCC & GND.
3.3v supply is generated on my PCB. supply to the JTAG is provided by Target board.
when i try to download to flash;i get error message "CAN NOT ACCESS MEMORY".
i want to debug this error message.
Let me know what should be the voltage levels at JTAG connector,so that i will be sured that this is hardware problem or software problem.
Mohan
