Kickstart version doens't produce correct code ( STR912 Bank1 )
Hi I have the following version of the compiler
IDE-Version:
µVision3 V3.53
Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2007
License Information:
XXX
YYY
LIC=----
Tool Version Numbers:
Toolchain Path: BIN31\
C Compiler: Armcc.Exe V3.1.0.903 [Evaluation]
Assembler: Armasm.Exe V3.1.0.903 [Evaluation]
Linker/Locator: ArmLink.Exe V3.1.0.903 [Evaluation]
Librarian: ArmAr.Exe V3.1.0.903 [Evaluation]
Hex Converter: FromElf.Exe V3.1.0.903 [Evaluation]
CPU DLL: SARM.DLL V3.11
Dialog DLL: DARMST9.DLL V1.02
Target DLL: BIN\UL2ARM.DLL V1.30
Dialog DLL: TARMST9.DLL V1.01a
I was trying to compile Blinky example (to boot from the bank1 of STR912). ( http://www.keil.com/support/docs/3347.htm)
Code compiles fine, loads fine, doesn't run. Now funny part is that executable Keil ships with the example loads and runs OK and drastically different size ( 20K vs. 5Mb! )from the code produced by evaluation version.
What gives? IS there is anything I can do to make evaluation version to behave?
Thank you
