Hello erveryone,
I've been searching for awhile and I just can't figure out what I'm doing wrong. I have a fully licensed keil compiler with the Rreal-Time Library version 3.2. If I use the provided compiled file of the http_demo and flash the MCB2300 micro controller, the DHCP works very well. If I compile the project though it's a different story. DHCP fails and I don't receive any IP address.
Any help concerning this issue would be greatly appreciated.
Eric Paulin
Hello it's me again,
Here's what the packet looks like coming from the MCB2300 if I compile the Http_demo example.
Frame 8 (1366 bytes on wire, 1366 bytes captured) Arrival Time: Apr 4, 2008 15:28:50.508872000 [Time delta from previous captured frame:2.434417000 seconds] [Time delta from previous displayed frame:2.434417000 seconds] [Time since reference or first frame: 14.681715000 seconds] Frame Number: 8 Frame Length: 1366 bytes Capture Length: 1366 bytes [Frame is marked: False] [Protocols in frame: eth:data] [Coloring Rule Name: Broadcast] [Coloring Rule String: eth[0] & 1] Ethernet II, Src: 55:55:55:55:55:55(55:55:55:55:55:55), Dst: 55:55:55:55:55:55 (55:55:55:55:55:55) Destination: 55:55:55:55:55:55 (55:55:55:55:55:55) Address: 55:55:55:55:55:55 (55:55:55:55:55:55) .... ...1 .... .... .... .... = IG bit: Group address (multicast/broadcast) .... ..0. .... .... .... .... = LG bit: Globally unique address (factory default) Source: 55:55:55:55:55:55 (55:55:55:55:55:55) Address: 55:55:55:55:55:55 (55:55:55:55:55:55) .... ...1 .... .... .... .... = IG bit: Group address (multicast/broadcast) .... ..0. .... .... .... .... = LG bit: Globally unique address (factory default) Type: Unknown (0x5555) Data (1352 bytes)
What am I doing wrong here? Anybody knows if the Http_demo example is compatible with version 3.2 of the Keil compiler and Real-Time library?
Thanks,
