among AVR 8051 PIC which is the fastest microcontroller in I2C,SCI,RS232 and SPI which communication is fastest?
Now you wouldn't be asking for an answer to a homework question, would you?
No, of course not, because that would be cheating.
this is not a home work question actually i have completed my studies i have taken a test for job from there i got these would u plz answer them
If you really want that job, you should read all related datasheet to answer your question by yourself. Trust me: it will help you get that position...
Not to mention that good skills at datasheet comprehension will be essential to keep the job once you have it (and of course it also helps with keeping those raises coming).
Hi man friend
Your first function may work yet even, if you are using the proper bit-time delay and this doesn't disturb with any IT routines. Maybe it's needed the disabling of all interrupts along it sends a char. However, the long delaying at the end is unnecessary, the overall speed (chars/sec) will too slow so.
But ... the coder will NOT work without any start bit falling edge detection. Now it get ever garbage only.
This detection is possible via polling or also via IT. And it's better using first a half bit-time delay after the detected start edge (and exit if the RX pin doesn't zero yet), and from here examine and get 9 times (after full bit-time delays) the pin value. The 9th bit is the stop bit ( do not store), but it must exist as a high level.
I'm wanted attachhere a zip with old but useful PDFs about this thing but can nnot.
Hope this helps zagn
thanks 4 urs advice
i is better for advice but forget all them
