ARM: Unable to use tftp over PPP
I successfuly configured Http_Demop and Telnet demo to work Over PPP using Keil RL_ARM 3.10. But i am unable to do so with tftp demo. I have a LPC2148 based Evaluation Board with no ETHERNET. can somebody help me!!!
The problem with TFTP demo is that i am unable to connect to my evaluation board windows dial-up. The same is possible with HTTP demo and Telnet demo.
Please help...
  • "i am unable to connect to my evaluation board windows dial-up."
    Please describe exactly what happens:
    - how far does it get?
    - what message(s) do you receive?
    etc...
  • I don't know how to enable debug and watch how far it is executed.. please help if possible..
    My net_config.c file has following things enabled...
    1 - PPP Interface with default parameters
    2 - UDP Sockets with No of sockets = 3 and highest port for autoselect = 1024
    3 - TCP Sockets default configured.
    4 - tftp server default configured.
    It also has a Filesystem File(which is in same as in the tftp_demo project). I changed only the RAM drive base address from 40000000(MCB2300) to 40004000(LPC2148).
    When i try to connect to board using dial-up connection it simply hangs and shows "dialing..." dosen't go any further. the same dial-up connection works for other PPP Projects.
    Here is a code fragment form tftp_demo.c
    int main (void) {
       /* Main Thread of the TcpNet */
       init ();
       init_TcpNet ();
       fformat ("");
       ppp_listen ("Keil", "test");
       while (1) {
          timer_poll ();
          main_TcpNet ();
  • Thank yo very much Andy for fast reply.
  • Thanks Andy... started debugging now... Will tell you where i stuck... with all the debug dump.
  • Following is the dump of my debug file.
    As soon as i type
    c:\windows>tftp -i 192.168.125.1 PUT a.txt a2.txt
    i get the udp error which is shown in the dump file.
    PPP: Initialize PPP interface
    PPP:  Initialize PPP-LCP
    PPP:  Initialize PPP-PAP
    PPP:  Initialize PPP-IPCP
    UDP: Initialize 3 Sockets
    TCP: Initialize 7 Sockets
    TFTP:Initialize 3 Sessions
    UDP: Searching for free UDP Socket...
    UDP: Free UDP Socket 0 allocated
    UDP: Socket 0, port 69 Opened
    PPP: Enabling listen mode...
    PPP:  Username: Keil, Password: test
    SPPP: *** Processing PPP frame ***
    PPP:  Frame len: 27 bytes
    PPP:  Protocol:  C021
    PPP: *** Processing PPP-LCP frame ***
    PPP:  LCP Config Request received.
    PPP:  Rejecting Unsupported Config Options.
    PPP: Sending PPP frame...
    PPP:  Frame len: 13
    PPP:  Frame len: 24 bytes
    PPP:  Protocol:  C021
    PPP:  Frame len: 16
    PPP:  Protocol:  C021
    PPP:  Frame len: 26
    PPP: Sending LCP Configuration request.
    PPP:  Frame len: 30
    PPP:  Frame len: 28 bytes
    PPP:  Protocol:  C021
    PPP:  LCP Config Acknowledge received.
    PPP:  Async Char MAP: 00,0A,00,00
    PPP:  Enabled PF Compression
    PPP:  Enabled ACF Compression
    PPP:  Magic Number: 345EB3F7
    PPP:  Enabled PAP Authentication Protocol
    PPP:  Frame len: 22 bytes
    PPP:  Protocol:  C021
    PPP:  Unsupported LCP Code received.
    PPP ERR: Rejecting Not supported PPP Code.
    PPP:  Frame len: 26
    PPP:  Frame len: 26 bytes
    PPP:  Protocol:  C021
    PPP:  Frame len: 30
    PPP:  Frame len: 18 bytes
    PPP:  Protocol:  C023
    PPP: *** Processing PPP-PAP frame ***
    PPP:  PAP Authentication Request received.
    PPP:  Remote Client login success.
    PPP:  Frame len: 18
    PPP:  Frame len: 14 bytes
    PPP:  Protocol:  80FD
    PPP ERR: Rejecting Unsupported PPP Protocol.
    PPP:  Frame len: 20
    PPP:  Frame len: 44 bytes
    PPP:  Protocol:  8021
    PPP: *** Processing PPP-IPCP frame ***
    PPP:  IPCP Config Request received.
    PPP:  Frame len: 38
    PPP:  Protocol:  8021
    PPP:  Frame len: 14
    PPP: Sending IPCP IP Config Request.
    PPP:  Frame len: 14
    PPP:  Protocol:  8021
    PPP:  Frame len: 14
    PPP:  Protocol:  8021
    PPP:  IPCP Config Acknowledge received.
    PPP:  IP address: 192.168.125.1
    PPP:  Protocol:  0021
    IP : *** Processing IP frame ***
    IP :  Remote IP: 192.168.125.2
    IP :  Frame len: 40 bytes
    IP :  Protocol:  02, Id: 0171
    PPP:  Frame len: 100 bytes
    PPP:  Protocol:  0021
    IP :  Frame len: 96 bytes
    IP :  Protocol:  11, Id: 0172
    IP :  Frame valid, IP version 4 OK
    UDP: *** Processing UDP frame ***
    UDP ERR: No Socket for received UDP frame, dumping..
    PPP:  Frame len: 332 bytes
    PPP:  Protocol:  0021
    IP :  Frame len: 328 bytes
    IP :  Protocol:  11, Id: 0174
    PPP:  Frame len: 165 bytes
    PPP:  Protocol:  0021
    IP :  Frame len: 161 bytes
    IP :  Protocol:  11, Id: 0175
    PPP:  Protocol:  0021
    IP :  Protocol:  11, Id: 0177
    PPP:  Protocol:  0021
    IP :  Protocol:  02, Id: 0178
    PPP:  Protocol:  0021
    IP :  Protocol:  11, Id: 0179
  • Note that the errors actually start several lines before your highlighting!
    It looks like you're initially allocating the UDP Socket OK at the beginning, but then failing to re-use it for subsequent packets.
    So perhaps you should be looking at the code that decides whether a Socket is available...
  • I checked my code. It is the example code which was originally written for Keil MCB2300 board with ethernet connectivity. I modified it to use PPP instead of Ethernet. There is no code i found which is using UDP packets directly. Tftp might be using them internally. So unable to modify the code. You can download the code for MCB2300 and My modified code from the following link. Please help.
    rapidshare.com/.../Both_Files.zip.html
  • Have you tried just searching for the text string, "No Socket for received UDP frame" in the source?
  • Yes... found Nothing... I think it is a library message....
    Here is the List of Which is included in the Project.
    (you can check the projects also.)
    Source Files
     1-tftp_demo.c  -- Main File
     2-tftp_uif.c  -- TFTP Configuration File
     3-serial.c  - Serial port driver for LPC214x
    Configuration Files
     1-Net_Config.c -- TCPnet config file
     2-File_Config.c -- File system config gile
     3-Retarget.c
     4-Startup.s -- Startup config file
    Library Files
     1-RTLTCP.lib -- TCPNet library
     2-RTLFS.lib  -- File system Library
