we are using code banking, from which using 5 banks.
When I compiled my program, I got:
linking... *** APPLICATION REQUIRES RE-TRANSLATIONS! ***
Does anyone know what it means? How can I avoid this?
is it only information, or need urgent attention on it.
Thanks.
Sachin Gole
There's probably an error/warning number that goes along with that. Since you didn't say what it is, I'll let you search:
http://www.keil.com/support/man/docs/bl51/bl51_errors.htm
In the meantime, 'clean' and 'make all' or 'build all'; whatever you think is best.
The easiest and quickest way to answer that question is to use the 'Search' box!
eg, just put "RE-TRANSLATIONS" into the box, click the 'Search' button, and you get this reading list:
www.keil.com/.../search.asp
