Hey, please excuse the lack of expertise, but it has been years since i've programmed and I am just getting back into it.
I have 2 questions.
1) Why are the standard libraries for Arm different than other standard C libraries. For example, the stdlib library is missing the itoa() function that is available for other compilers. Can I use these libraries for the Arm or do i need one that is specifically made for the Arm compiler. Another example is string.h, where in the past i remember being able to create a variable using the typedef "string" where as in now i cannot.
2) Is there an easy alternative to converting an integer to a string?
Any help is really appreciated. Thanks Omer
2)
Don't mention "standard libraries" and itoa() in the same sentence. itoa is not standard.
There are a number of alternative methods to convert a number to ASCII. The most general is normally sprintf() or snprintf().
string.h and the datatype string are two completely different entities.
string.h contains the declarations for use with C-type zero-terminated strings.
C++ has the std::string data type (previously known only as string) but then you should write
#include <string>
and not
#include <string.h>
Thank you PW for your quick response. I tried using #include <string> several times with no avail. Each time i get the following errors:
C:\Keil\ARM\RV31\INC\rw/_defs.h(781): error: #20: identifier "namespace" is undefined C:\Keil\ARM\RV31\INC\rw/_defs.h(781): error: #65: expected a ";" C:\Keil\ARM\RV31\INC\wchar.h(107): error: #20: identifier "size_t" is undefined C:\Keil\ARM\RV31\INC\wchar.h(107): error: #20: identifier "size_t" is undefined C:\Keil\ARM\RV31\INC\iosfwd(93): error: #20: identifier "namespace" is undefined C:\Keil\ARM\RV31\INC\iosfwd(93): error: #65: expected a ";"
Notice that <string> is a C++ include file, and "namespace" is a C++ keyword.
Are you sure that you are compiling C++ source code, and not C code?
If you are going to work with C++, I would also recommend that you read up a bit about namespaces, since the C++ runtime library has been moved into the std:: namespace, to follow the current ISO C++ language standard.
