Three USBCDC Interfaces support in usbser.sys ?
I want to know that if USBCDC with three or more interfaces is supported by using usbser.sys. I can see three VirtualCOM in PC, but one of them shows "not used" in Windows Device Manager. So I can't open it with COM Port program, but the other two VirtualCOM ports work well.
Somebody knows why ? Thank you !!
  • Any numbers of CDCs are realized on a composite device.
    I have once done quick (and dirty) test of a composite device of five CDCs for fun :-)
    a) Descriptors
    For CDC descriptors, the interface numbers are referred many times.
    Check the interface numbers on the interfaces.
    Interface number for communication interface
    - IAD
    - Interface desc
    - Union Functional desc
    Interface number for data interface
    - Call management desc
    - Interface desc
    b) INF file
    Did you add the device IDs for each interface to the INF file?
    like
    USB\VID_vvvv&PID_pppp&MI_00,
    USB\VID_vvvv&PID_pppp&MI_02,
    USB\VID_vvvv&PID_pppp&MI_04
    A single INF can support all interfaces
    c) Observe the enumeration just after plug in, using a sniffer.
    If you don't have a hardware bus analyzer, download this trial and 'evaluate' it. I hope your trouble will be solved by its "rich features" even on the evaluation :-)
    SourceUSB
    http://www.sourcequest.com/
    Does the three interfaces give the same enumeration sequence?
    Any difference on the failed one?
    Tsuneo
