Dear All,
I am trying to send constant character for testing my serial ISR routine behavior. With following code I am not receiving any characters at PC hyperterminal.
void init_serial(void) {
SCON = 0x50; T2CON =0x34; RCAP2H=0xFF; //57.6K Bds at 20 MHz RCAP2L=0xF5; //57.6K Bds at 20 MHz
ES = 1; // Enable serial interrupt TR2 = 1; // Timer 2 run TI = 0; RI = 0;
} // end void init_serial(void)
static void MODEMHandler(void) interrupt 4 using 2 {
unsigned char RxData; if (RI)
{ RxData = SBUF; RI = 0;
} if(TI)
{ SBUF = 0x41; TI = 0;
void main(void) {
init_serial(); EA = 1 ; /* enable global interrupts */
while(1)
TI = 1;
What's the wrong with this code?
Thanks.
Why do you have a while loop to set the TI bit? Don't you think a single assign would be enough to kick-start the transmission?
